La Marzocco Linea Mini - How to remove front panel?
Update: I spoke with Chris at La Marzocco and he recommended against taking disassembling any further since this would require taking off the boiler, etc.
So for anyone else contemplating doing the same, it appears that the expert recommends you don't.
How old is your unit? Curious to know how old it was when you experienced this issue. Thanks!
I'm dealing with this exact situation, diagnosed a leak which is a vacuum breaker. Noticed the rubber tubes look dirty and wanted to replace them but the front panel is in the way of the drain tube. I also noticed some corrosion around the group head so I removed the entire top front panel.
I'm soaking some parts in a descaler while waiting on the replacement valve. Maybe we could be some help to each other.
Daniel
Daniel
