La Marzocco Linea Mini EMP Mod - Page 6
This is Rick's first pressure profiling mod that doesn't change the pump pressure, but instead bleeds off water to lower the pressure into the group. In other words, the pump stays a constant pressure, you control the pressure by bleeding off water into the tray. A lot of flow profiling machines do this.mirekti wrote:In one of the GS3 MP videos on YouTube a guy complained it "waists" a lot of water when changing the pressure and he's annoyed to need to refill the tray very often.
What's your experience with Rick's mod? How many shots can you pull out of full tray?
Also, did you mod the gigleur to 0.6mm as well?
The EMP mod is wholly different. It is a complete swap of the pump that makes it variable speed, which controls the pressure by adjusting the speed of the pump.
JettLag wrote: The EMP mod is wholly different. It is a complete swap of the pump that makes it variable speed, which controls the pressure by adjusting the speed of the pump.
What water pump and motor does Rick use for his EMP mod?
The pump is a fluid-o-tech pump, off the shelf item. The motor is a DC motor - I don't know the brand. It is also available commercially but I can't tell you the brand.
Howdy - I have this mod, and cannot recommend it enough. The shots you get are fantastic and It's sooooo quiet, it's amazing. You'll have to re-learn how to pull a shot with pre-infusion, but it's well worth it. Yes, it does void the warranty. I purchased my LM in 2018 with a view to modify to the needle mod, as I couldn't afford a Slayer. When it was mod time, voila new mod type (EMP). Couldn't be happier. No longer have FOMO on a Slayer, R9 or any other machine (well apart from just the look of a Kees Vander Westen Speedster!). I waited until my warranty expired before upgrading...but if I had my time over, I'd just void the warranty on the machine and upgrade. It's that good. Rick did the upgrade for me (it's #004), but looking through the process if you're handy and patient, you can do it from the instructions. It's also been updated with some Specht Design Bling so looks awesome. It's paired to a Compak F10 Conic OD, which has a bit of retention (~2gm) and ~3sec grind time. I have a few espressos to brighten my day, so I load up 3-4 shots in the morning and it's great. 98mm Flat Burr Grinder would be the only future upgrade on my path to espresso heaven.
Flair 58 looks awesome. Be great to have it as a backup or just to have while travelling. Now to find one with an AU Plug!
Great thread. After 4 years of running my lmlm stock, I'm ready to change things up a bit. I emailed Rick to purchase this mod. He recently changed out the pump to a procon model.MESS wrote:What water pump and motor does Rick use for his EMP mod?
https://www.instagram.com/s/aGlnaGxpZ2h ... MyMTA2M2Y=
You are going to be blown away by the mod. It completely transforms the LMLM. Enjoy the process.
