La Marzocco Linea Mini - $650 repair! - Page 2
- drgary
The technician suggested a brand of bottled water. If this was a LM technician, it looks like the problem is solved.gooner wrote:Thanks all! I knew water is high in chloride in AZ so i switched to bottled with a low TDS/hardness within LM range, but still had this issue.. Moved to a recommended brand of bottled water from the technician after I had this issue and will take it from there I guess.. Continue to drain/backflush once every 25days or so and hope for the best.
Also feels weird using my steam wand on 1.0 pressure after getting used to the 1.5 for that long
LMWDP#308
LMWDP#308
