La Marzocco GS3 makes weird sound like always heating
Hi there!
I have seen this thread La Marzocco GS3 constantly heating and I am not really sure if my GS3 has the same problem. I have uploaded a video of my GS3 in which you can hear and "see" the noise (I can hear it very well on my phone, I hope the quality is good enough) you can find it here:
Does someone here know why my GS3 sounds this way?
Is there a piece I can replace or check?
Best regards
D, gs3_beginner
Best regards
D, gs3_beginner
- slipchuck
Sorry can't hear anything
Randy
Randy
Hi!
Yes, the Video is not the best at all. I have tried to record just the sound without Video. This should be better: The video it self is just black.
It looks like the youtube upload removes a lot of the audio quality
How old is the machine?
Mine started to sound like this after about 6 years. A brand new steam boiler element fixed the issue.
- HB
- Admin
It's difficult to be sure from the video, but it sounds like a steam boiler leak from the vacuum breaker is not closing completely. If you remove the side covers and use a rolled up paper tube as a stethoscope, you should be able to pinpoint the source. Of course, the site's terms of service applies:
Home-Barista.com - Agreement - Part II wrote:The Home-Barista.com forums are provided for informational purposes only. Espresso equipment contains controls and conduits for electricity, very hot water, steam and high water pressure. Attempting repairs, modifications, alterations, or diagnoses of such equipment yourself could result in serious injury or death to yourself and to others and the destruction of property by fire and other causes. We accept no responsibility for any injuries or losses resulting from any attempt to perform equipment repairs, modifications, alterations, or diagnoses based on information from Home-Barista.com.
You guys have good ears! All I hear is what sounds like a car going through gears!
OK, I will give a try next week and keep you updated. Thanks!HB wrote:It's difficult to be sure from the video, but it sounds like a steam boiler leak from the vacuum breaker is not closing completely. If you remove the side covers and use a rolled up paper tube as a stethoscope, you should be able to pinpoint the source.
