Izzo Alex Leva Springs
silkypull
#1: Post by silkypull »
i've checked on HB and from previous post, there's been info about removing the inner spring on the Leva for different taste. I saw a post from Tom before that with both springs is about 11bars of pressure, where as if just outter spring only, it's about 8.5 bars of pressure. anyone tried to find a spring that would product 9bars of pressure?
i don't know much about compression springs, let alone about leva... but the thought has crossed my mind to see if that's something that has been explored before?
and even if a compression spring exist that will product 9bar or pressure, how would the boiler temp/ pressure play into that? just curious as to the relations between the current boiler temp/PSI vs the current grouphead spring pressure.
thanks.
LMWDP #663
