Izzo Alex Duetto III - Too high rotary pump pressure
Philipp85
#1: Post by Philipp85 »
Hi,
My Alex Duetto III is having a too high pump pressure when I am pulling a shot. It starts with 9/10 bar and then a new sequence starts and the pump pressure increases to 12 to 14 bar. Could the pump be defect? I have not tried to adjust the pump pressure as the pump seems to have two modes.
JRising
#2: Post by JRising »
Very likely just needs the o-ring lubricated. If the o-ring is hard as rock, replace it.
(Talking about the o-ring inside the pump-bypass adjustment part of the pump, it's there to keep the pump from weeping out the breather hole, but when it gets sticky the valve stops being accurate).
JRising
#3: Post by JRising »
At work, now... Can copy/paste pictures.
Part 18 is the o-ring in question, it goes around part 19.
Philipp85 (original poster)
#4: Post by Philipp85 (original poster) »
Thank you! It fixed the problem :D
