Izzo Alex Duetto II - Gicar PID Controller Button Issue
Postby benspresso » Aug 18, 2017, 12:40 am
Hi all-
I have an Alex Duetto II I've been using successfully for almost a year now. Only have had to replace a leaky pressure relief valve, but nothing else until now.
This morning, I attempted to adjust the temperature of the main boiler using the PID controller. However, when I pressed both left and right buttons at once (to enter adjustment mode), I was unable to enter the adjustment screen.
Upon further research, I found a way to "reset", as well as enter "diagnostic mode" on the PID controller, which required holding both buttons at once while powering on. I kept getting the screen that you're supposed to get when only the RIGHT button is held down. This leads me to believe I somehow lost function of the left button.
This happened out of nowhere. Does anyone know what I can do? I'm currently unable to adjust temperatures on my machine. I'm considering just taking apart the controller and rebuilding it, but wanted to seek advice here before taking any further action.
Image of the controller, for reference (possible left button not responding):
Postby chipman » Aug 18, 2017, 1:46 am
If I were you I would call CCS before doing anything on my own when I obviously don't know what's wrong.
Postby ASRBriggs » Sep 14, 2017, 4:28 am
Did you get a resolution to your issue Ben? My Alex Duetto II does exactly the same thing.
BaristaBoy E61
Postby BaristaBoy E61 » Sep 14, 2017, 11:14 am
+1 for calling Chris' service dept.
What's that cap on the Mushroom?
Postby dmw010 » Sep 14, 2017, 11:24 am
My original blue display failed less than two years after I bought my Duetto II new. I never had a problem with the buttons, but individual segments of the display began going dark, eventually making it unreadable. I purchased a replacement red display from CCS. About a year later the same thing started happening. CCS warrantied it, but had no idea what was causing the problem. So far so good on the third display.
Postby Igneous » Sep 14, 2017, 4:12 pm
I'm having the same issue as OP with my PID. Did you ever figure out how to fix it or did you replace the PID?
Postby ASRBriggs » Sep 16, 2017, 12:32 am
Well I resoldered the switches. Still doesn't work.
Soaked it in isopropyl alcohol overnight and let dry. Still doesn't work.
If anyone else has ideas i'm listening!
Postby jerbear00 » Sep 30, 2017, 1:22 am
Did you call Chris coffee service? Seriously, they have helped me out of my duetto more than once. Each time I wish I'd asked sooner.
Link to new PID otherwise:
Postby gtemkin » Sep 30, 2017, 9:47 am
Don't know if it's the case here, but the dome switches used in these thin panel products often go bad, especially in the hot conditions of an espresso machine. The better quality domes are heavy gold plated, but more common are domes with very thin gold plating or no plating at all. A non-conductive, oxide layer develops at the contact interface and the switch no longer conducts when actuated. Dome switches don't have any wiping action that would clean the contacts, so once they go bad, they rarely improve. My old paper shredder has dome switches and it's buttons wouldn't react to presses, at first sporadically, then every time. Measured the switches for continuity and they were very high resistance on actuation. Replaced the switches with new ones and switches works perfectly.
Postby Igneous » Oct 04, 2017, 9:29 am
Thanks for the insight, gtemkin! Is this something that a layman could do? I'm guessing you would need tools to replace switches. Would it just be best to buy the new PID controller for $140 from chris' coffee?
