Isomac Rituale Millennium red/green lights out
George
#1: Post by George »
Hi. Our isomac rituale is not working right. The gauge doesn't register anything and the red/green lights are out on right side. It was happening sporadically and now is completely off. Any ideas on the problem?
slipchuck
#2: Post by slipchuck »
Is it a pour over version?
It could be the water tank level switch that's faulty
Randy
George
#3: Post by George »
Pour over? I put the water in the tank. Is that what you mean?
Thanks for responding
slipchuck
#4: Post by slipchuck » replying to George »
Yes that's what you mean
Randy
George
#5: Post by George »
Where can I find the water tank level switch?
nahau
#6: Post by nahau »
Not sure what year your machine is but here is a parts location drawing from Espressocare. You machine may be laid out similarly...
https://www.espressocare.com/assets/upl ... mplete.pdf
The water level switch should be #31... near lower right hand corner.
And here is a schematic, complements of HB member erics. If the water level switch is bad, you will not get power to the machine.
userpix/269is_elec3_small_3.jpg
RobAnybody
#7: Post by RobAnybody »
George wrote:Where can I find the water tank level switch?
Underneath the water tank is a spring loaded plate, the switch is underneath it. You'll have to take off the back cover to be able to see it.
These fotos are from mu Isomac Amica(it uses a comparable casing)
The switch is on the left in front of the vibe pump
And this is how far you have to take it apart to comfortably work on it.
Cheers,
Rob
LMWDP #647
