Isomac Meltdown
I recently noted that the pressure pump on my 10 year old Isomac Millenium was staying on way longer than normal, the pressure gauge went to max before I was able to turn the machine off (the gauge looks to have been damaged, remaining at 6 O'clock. I have replaced the Pressure Stat and the Boiler Safety Valve thinking this to be the cause of teh problem. Restarting the machine the problem remains though I note that the boiler is now failing to cut off, building up steam/water that is venting via the safety valve.
I have disembled the solenoid valve, looks ok, but i do not hear a click when the macine is turned on ( i think i hear a click as it cools down?)
I am not sure where to look next! Any thoughts?
its seems like the solid state relay is stuck in the on position. look and see what type of one you have (its a whiteish box that has 4 wires going into it) and then replace it with a new one. that should work
Thanks SamBuist. I will have a look at the solid state relay and will report back
I would open the black brain box (where all the wires lead to) and see if there is any corrosion etc visible on the board. I did have an isomac that was acting strangely and it turned out to the board.
