Isomac Itala thermal fuse
- cafeIKE
Ian's Coffee Stuff
- cafeIKE
Does the boiler heat?
This is a snip from a Zaffiro at site sponsor EspressoCare
It appears there is a fuse as well as the thermal breaker, which appears to be self resetting. The fuse is a safety against the breaker fail closed.
The fuse requires insulation and a clip to hold it to the boiler.
Ian's Coffee Stuff
It stopped heating, and I think heating element has been burned.. Thanks for the picture, I guess I just have to get that clip and a screw to install that thermal brake. There is a screw hole on the top of boiler
- cafeIKE
This wiring diagram for a Zaffiro might help.
If you don't have one, a VOM is essential. A set of clip leads as opposed to probes makes life easier.
When working with 220V, and using a probe to find a fault, using one clip lead and one probe allows you to keep one hand in your pocket.
Ian's Coffee Stuff
- BaristaBoy E61
Sage advice to not get fatally electrocuted when working with a live circuit.cafeIKE wrote:When working with 220V, and using a probe to find a fault, using one clip lead and one probe allows you to keep one hand in your pocket.
Double check the temperature value of the thermal fuse against the original parts list or schematic!
