How to clean a Bellman steamer? - Page 2
- spressomon
^^^ (where's hands clapping when needed?!). Thumbs up!
No Espresso = Depresso
Thanks. Your posts helped get the ball rolling. It went very well this morning...
Major Bellman stovetop steamer breakthrough!
Von meinem iPhone gesendet
short of performance issues, is there any way to evaluate potential blockages in the PRV or Steam Wand? I imagine you can't inspect this visually . Bought a used electric bellman in good condition, but want to guarantee that there won't be a dangerous buildup of pressure? ThanksJonk wrote:If you don't let air out through the pressure release valve or steam wand before steaming that could perhaps be causing big bubbles?
As for the OP, if you suspect the valve is blocked you should probably replace it https://prima-coffee.com/parts/bellman/a-25
also, will any of the gaskets for the 50ss (the ones available on prima coffee) fit in the CXE25?
