Help with La Pavoni Domus Bar electrical problem - Page 3
Ordered and replaced the three way valve. No leakinh through the group head now, but instead it leaks out the drain. Still leakage though. It doest stop until I turn off steam. So all steam leaking out.Javierba wrote: With that said, you can find the olab three way valves very cheap in aliexpress
Should the three way valve close when turning steam on? When I turn the pump on I get 230V going to the valve, but 0V when turning on steam.
The three way walve should only be powered (connecting the boiler and the brew head) when the pump is turned on, otherwise has to be powered off (connecting the brew head to the drain)
Thanks! With the new three way valve the steam leaks to the drain instead of the group head as it did before. But should not leak at all, it should stay in and only getting out when opening the steam wand. Any idea what part to look at?
http://nibra.altervista.org/wp-content/ ... re2007.jpg
I'm not sure what you're saying. The steam wand and the brew circuit's 3 way valve are not connected.
If you're saying that the pressure is escaping the boiler through the three-way valve's drain with the valve NOT energized (not brewing), do you maybe have the three-way valve in backward? Ie, It's got the port that should be connected to brew-head connected to boiler and vice versa?
looking at the picture you sent, this looks like a 2-way solenoid with a T connection screwed in.
anyways
As JRising mentioned if you have the valve the wrong way around the steam pressure will force the valve open and you will have it leaking to the drain.do you maybe have the three-way valve in backward? Ie, It's got the port that should be connected to brew-head connected to boiler and vice versa?
cheers,
Rob
LMWDP #647
Of course! Thats it! I put it in the wrong way, fixed it and now I think I'm done!RobAnybody wrote:image
Thanks everyone for helping out! I've learned a lot about this machine, thanks to you guys. Looks like everything's working properly now. Hope it continues that way! All the best!
