Help getting a heating element out of the boiler
- BaristaBoy E61
Would applying heat possibly help?
I was thinking about that. I have a nozzle that attaches to a small propane tank - I can try gently heating. Any concerns about putting a flame to it?
- erics
- Supporter ★
Rent or buy an electric impact wrench and it will come loose easy. It needs a 1-1/2" socket if I remember correctly.
I got the socket - it's a 1 7/16". I tried to rent an impact driver but was told it wouldn't have enough torque to get it off and would damage the driver. I figured a hammer would do the trick but I cannot get it to budge.erics wrote:It needs a 1-1/2" socket if I remember correctly.
- erics
- Supporter ★
It would not damage the driver but that would be difficult to argue with the person behind the counter.
Then take the machine to your favorite mechanic or tire store and have them loosen the "nut" with their ADJUSTABLE impact wrench.
Would soaking it (or filling the inside of the boiler with) Citrix acid solution help?
As it happens, I had an appointment to get my oil changed today so brought the boiler with me. The mechanic got it open without any problem. Amazing how well the air impact driver works!erics wrote:Then take the machine to your favorite mechanic or tire store and have them loosen the "nut" with their ADJUSTABLE impact wrench.
Just don't use an impact driver if you're removing a known good element for cleaning...
The impact will likely crack the element. Ask me how I know
Hopefully mine is not cracked! Is there an obvious way to know or only after everything is back together and it won't heat? There was no way that thing was coming off without an impact driver - I was hammering the wrench and it wouldn't budge. Chris coffee recommends removing the heating elements using an impact driver - so hopefully things will be ok.schwaggy wrote:Just don't use an impact driver if you're removing a known good element for cleaning...
What started as a simple gasket change has turned into a complete tear down and rebuild. Hopefully I can get the thing back together again!
