Gasket removal tool - Page 2
I saw the same on amazon for $4. I wonder if its the same quality or just a cheap look-a-like.
I use a wood screw, but have also used a cork screw once. Unless the gasket was in situ for decades they are fairly easy to remove IME, silicone is even easier to remove.
LMWDP #483
- cafeIKE
- Supporter ❤
Get a CafeLat silicone gasket. It's a one time purchase and light years better than lubing a hard rubber gasket.Nunas wrote:When you put it back together after servicing, put a light coat of food-grade lube on the portafilter gasket. This makes it come out more easily the next time. I do this every time.
Ian's Coffee Stuff
