Favourite espresso machine repair tools - Page 2
- JohnB.
Not at all. With both side covers & the top cover off it's wide open with easy access to all fittings. The 2020-on models were redesigned inside & have even more free space between fittings then the older ones like mine.BodieZoffa wrote:Must be some TINY space in that case...
LMWDP 267
One side is left-handed, the other side is right-handed - or - if you were taught a long time ago to always pull in the direction of the sliding jaw, one side is for tightening and the other side is for loosening
- My espresso: Swirled, not stirred. My pourover: Stirred, not swirled.
- Jeff
Knipex plier-wrenches, with or without the soft jaws, are expensive, but a joy to work with.
Well-fitting screwdrivers, such as PBSwiss, Wiha, or Wera (PBSwiss are, unfortunately, even more expensive than Wiha and Wera).
For cramped spaces a ratcheting 1/4 bit driver. I happen to have a Felo, there are several brands out there. The "ultimate" for close quarters is the Engineer DR-54 (https://www.tme.com/us/en-us/details/fu ... eer/dr-54/ or various eBay sellers)
From TME.eu:
I also picked up KNP.8111250 which looks like it will come in handy for something. (Like stubborn piston-mounting caps in a VAM.)
From TME.eu
From TME.eu:
From TME.eu
- IamOiman
I got some bitties I can recommend not counting the stuff already mentioned (the Knipex especially)
My little magnetic tumbler. I use it on every project, and it will clean up just about anything that is non ferrous (although I have cleaned up a few small pieces), and it will keep the plating in the process. My Vevor KT185 will not clean off stubborn gasket material but besides that I am very pleased with it. I use pins and cleaning powder from Guntap.
I like to use the tumbler and my sonic cleaner together (The Vevor I currently have is the one on the right. The left one is the Harbor Freight cleaner I broke before purchasing the Vevor). The latter preps the pieces for the former. I have a 6 liter size, and it fits most pieces I clean it with, although perhaps in the future I will also get a bigger and smaller size too.
My bearing separator from Harbor Freight was a good purchase to remove bearings from lever forks. It is also one of my first specialty tools I bought
For pistons with pin holes on the face I use an OTC 6613 pin spanner wrench, normally used on car brakes I believe.
Electrical wiring I have a Doyle wire clippers, a now no longer available ratcheting crimping tool, and a Klein Tools wire stripper. The 14AWG TGGT wiring itself is high temp, as are the AMP PIDG terminal connectors I use. For toggle switches I use the NKK brand, also highly recommended.
When I need pipes made I use Cupalloys 2mm diameter low temp silver solder and a MAP Pro torch. The fittings I purchase from a Nuova Ricambi distributor, and they are really good for making sure I am getting the right fitting size for the pipe and thread. I use a Rigid pipe cutter and a random chamfer/deburr tool for cutting and cleaning the copper pipe. I use a no-name pipe bender and it works fine for soft metals.
In terms of cool factor I think my factory Gaggia Espanola 80mm spanner wrench is up there. I wonder who used it last before me
-Ryan
LMWDP #612
LMWDP #612
- BaristaBoy E61
An amazing and wonderfully informative post Ryan.
Thanks for sharing so much of what you do.
A roll of duct tape, vice grips, this. What more would you need?Giampiero wrote:This one it fix everythingimage
Indeed a cool post Ryan.
I'm familiar with what a sonic cleaner does (have been on the fence purchasing one for a while now to clean chains, cassettes and other greasy items), but what is the difference with a magnetic tumbler? Haven't heard of that before, but those shiny parts make me curious.
I don't want a Decent
- IamOiman
The tumbler spins little pins that clean the surfaces of the dirty parts you want to work on. Water and cleaning detergent are added for enhanced cleaning
-Ryan
LMWDP #612
LMWDP #612
