Elektra Modern Maxi repair help
colbinious
#1: Post by colbinious »
hello!
This is my first time trying to repair an espresso machine. It is an elektra modern maxi group 2 from 2002. I was able to make enough repairs to get it to this point but reached my first roadblock.
When it is turned on the machine makes a clicking sound. Most of which is the solenoid activating the pin. I took it out and tested it and the pin pulls up and down. The motor will not engage but the heater will turn on. I have tested all the components with a multimeter and it is getting the required 220v plus everywhere.
there is a video of where the machine is at currently.
any tips on where to go next is appreciated.
Thank you
colby
MatGreiner
#2: Post by MatGreiner »
Is the clicking coming from the Pressurestat? That's a part that needs replacement once in a while. There may also be a water inlet solenoid.
Does the pump (motor) operate in isolation?
Espresso Vision: the perfect cup of coffee starts with understanding your roast
Sponsored by Espresso Vision
ira
#3: Post by ira »
If I was guessing I'd say the Power Supply in the control box is dying, either the bridge rectifier has lost a diode or the big capacitor needs replacing. Can you show us a picture of the board inside the controller?
Ira
