I picked up a second hand ECM Giotto premium pretty cheap. My machine turns on and the lever engages the pump which pumps water through the group head but no heat. I didn't do too much diagnostic work whilst it was all together as I always intended to completely strip it and clean it.
I was searching the internet for info on this machine which found this site and this thread in particular Rocket Giotto Premium Plus won't start - Diagnostic help appreciated
I was hoping to just ask a quick question in that thread, but unfortunately it is closed.
I have pulled all the piping components and the boiler apart and it is pretty badly scaled, so those have had a first pass with descaler, I rinsed everything and will have another go in the next few days. I have always suspected it is an electrical issue or a pressurestat. So whilst I had the boiler removed and full of descaler I started continuity testing the wiring and most seems to check out, however, continuity testing the PCB mounted transformer yields nothing (neither primary nor secondary winding), perhaps it isn't supposed to and I am confused but I think this tells me the transformer is FUBAR. So in a similar situation to the linked thread, i need a new transformer, however, mine does not have a nice clear part number on it to search for so I think i have located the correct part but would appreciate some confirmation from those in the know.
Here is the current transformer
this is the part i believe is a suitable replacement http://au.rs-online.com/web/p/pcb-transformers/7320342/
I will (when I get a minute) post up photos of the restoration process
Thanks, much appreciated
