E61 group head lever reinstall
I took the group head apart apart to replace lower cam pin on my quickmill anita. Everything seemed to be fine until last piece of the lever cam which has a very hard spring (red arrow) toward the end of the lever. No matter how hard I push, I can't lock the nut at the end of the lever in with the spring there. What's the function of this spring? Can I leave it out?
- Jeff
As I recall, that spring compresses the packing washers to help ensure a seal around the shaft.
https://www.chriscoffee.com/blogs/espre ... loded-view
You installed the spring/nut assembly in the wrong position.
Is this the right sequence? You mean the sequence is right but the position is wrong?
I did not find another photo, but the nut/spring assembly, as you show, must to go between the big chromed nut and the small chromed nut.
- BaristaBoy E61
100% your sequence was wrong. Part# 460079 goes between Part# 460078 & Part# 460081 with the flange against the rubber washers so that the spring can project tension on the flange against the washers to prevent leakage.
Yup, wrong order. When you follow that diagram, you will see that it is easy to reassemble.
Thank you all so much. My sequence was totally wrong. After I fixed that everything goes in place very easily. After I put it all back, I tested a shot to see if I fixed the drain valve problem or not. It turned out I still have no draining after pulling a shot or backflush.
I had very similar problem with this old thread I found
Quickmill Alexia: replace worn exhaust cam pin?
The lower cam pin was totally worn out which was the reason I replaced it.
I replaced the cam lever and the gaskets as well. I bought this machine about 6 years ago from a guy who had it for 2 years and been using it regularly. Is there any other parts in the drain valve that's known to wear out from usage that I should change?
I would suggest replace that pre-infusion valve (in the picture) completely, the cam-rider is worn at a sharp angle and the valve face is completely crapped out and extruding from the valve. Also examine the drain valve (The one below that one in the machine), if its rubber is as bad as that pre-infuse valve, replace it too.
