Conti Empress project begins again - Page 2
Madscrambler
#11: Post by Madscrambler »
thanks for the helpful Suggestions all for the seal I need ! I contacted Café Parts and they are checking to see if they have something.
Madscrambler
#12: Post by Madscrambler »
The end plug gasket i think i can replace however the disk one is proving more difficult to locate.
Swissbariss
#13: Post by Swissbariss »
Returning to a project 20 years later must bring back (hopefully) happy memories. Boiler looks amazing.
orphanespresso
#14: Post by orphanespresso »
These cool Empress steam and water valves are reasonably easy to rebuild using stock rubber sheet and cord from mcmaster carr. Make sure you use a high durometer cord on the end piece and specify "high strength EPDM" for the sheet to make the big discs. high strength has a higher temp rating. i used center punches to cut the discs. EPDM might work best since silicone rubber may be too soft. also, for those end seals I think the old Faema E61 machines use some that are a direct fit and really hard durometer, but a length of cord and a square foot of sheet do a lot of valves.
★ Helpful
