Classic Coffee Gaggia Rework - Page 2
- ricca509 (original poster)
Yes I did, it was already too late when I took the picturepizzaman383 wrote:Did you remove a screen from the group head before taking your last picture? If not, you are missing the dispersion block and the dispersion screen.
LMWDP #584
Mine is an Ulka EP5TheCappuccinoKid wrote:Just to confirm any differences between our Classics, that last photo shows what it pretty much looks like inside my silver standard edition Classic (circa 2001, around). You appear to have the alu. boiler, as mine has, so we're both fortunate for that. Not sure if the pumps are the same. Mine has an "Invensys" pump. Yours could be either Invensys or a 220v Ulka.
LMWDP #584
Taking the boiler out
Before moving the boiler I wanted to make sure that all connections were marked/photographed, I don't want to come back next week and have no idea where to connect all the wires.
First, mark all the boiler connections
Thermostat 1
Fuse
Disconnect the OPV valve
Number the second thermostat's connections
And off it comes!
Detail of the solenoid valve and OPV
The chassis is quite rusty on the inside
Thermostat 1
Fuse
And off it comes!
LMWDP #584
Interesting, in that yours appears to be a 1995 machine, mine I believe is around 2001, but they used an Ulka Ep5 in the earlier model, not the later one. I'm guessing the Invensys is a better pump, as the EP5 is the cheapest of the Ulka's. (Shouldn't make too much of a difference though, as far as coffee production is concerned...).ricca509 wrote:Mine is an Ulka EP5
<image>
It is indeed a 1995 machine, to be exact the bottom says "09 95"
LMWDP #584
Cleaned the boiler and group head, and I've also received the Gaggia Classic (Pre - 2015) Service Kit
Will start putting it back together asap, test it for a while and then decide on the chassis color!
LMWDP #584
I've eventually come round to change all gaskets and the two thermostats that came in with the service kit.
This is the boiler cleaned and back together
Also cleaned the solenoid and OPV
New pieces
In the meantime, I've also received the bottomless portafilter with 21g Basket and the Pre Modified Rancilio Silvia Steam Wand for Gaggia.
A comparison of the new and old steam wand
And here is the new wand installed
New pieces
LMWDP #584
- pizzaman383
- Supporter ❤
You might want to consider lapping the bottom surface of the boiler top. The aluminum can pit and that is typically what causes leaks. The lapping can help make sure that you can see if there are any pits near where the gasket o-ring seats. If so, you can take off more material until it is clear for the seal.
Curtis
LMWDP #551
LMWDP #551
