Breville Infuse Running Loud and Cold
Our Breville Infuser has been getting increasingly loud as of late and today it suddenly started putting out cold shots. Has something finally crapped out? Sadly its a weekend so I can't call them. I'm open to fixing it myself I just can't find any online resources.
Thanks
Josh
Thanks
Josh
Can you describe the loud sound? Is it a buzzing?
Gradual buzzing loudness is usually the brew solenoid on this guy. Cold temp is either the heating element or something in the control board.
I've never repaired any electronics on Breville machines before (TBH, they're a hassle to work on because they were never designed to be repaired).
Nick
Nick
yes its an increasingly louder buzzing.
coffee not getting warm even when we let it warm up for 10 min.
In this case your brew solenoid should be replaced.
In terms of the heating issue, it can be your element, your control board, or a connection between them.
The wiring in these guys is not very friendly. If you have a multimeter check continuity and check resistance across the element.
Nick
Nick
