Bezzera Magica hot water tap leaking
Machine is about 3 years old. No problems until just recently, I found the counter top wet. Actually, a towel I keep laying next to the machine on the side where the hot water tap/wand is was soaked. I put a large glass under the hot water wand and sure enough, it was half full of water by the end of the day. I work from home and the machine is on from 5 am till 3pm. I don't use the hot water wand often. Occasionally I'll make an Americano. I suspect something inside the tap body is allowing water to leak by. This machine has the joystick type controls. I'll probably be a little different than most when I say, I prefer knobs. So... I'm thinking, if I'm going to have to replace this tap assembly, is there a knob version I could use out there? I don't care if it's by Bezzera or anyone else. What the knob says on it, I don't care. Just looking for an informed opinion on what assembly I might be able to use.
Thanks in advance.
Thanks in advance.
Just take it apart, clean it and replace the seal (if needed). This is quite common and easily fixed.
Thanks, I pushed it in all directions wondering if maybe it wasn't sealing etc. Seems to have stopped, but I will get an extra seal ordered and have on hand.
