Breville Barista Express steam very wet
Fixing a BBE BES870 for a friend.
When steaming the pump continuously runs and there is a good deal of water in the steam. I have just descaled with citric acid. On a boiler machine I would adjust the water level sensor, but not aware of this on a Breville thermocoil.
Wondering if anyone has experience with this problem.
- slipchuck
I used to own one and through my experience water in the steam is par for the course
Randy
Randy
- d_leonit
Does it use more than one heater on the thermoblock?bob wrote:Fixing a BBE BES870 for a friend.
I own a BE. What you are seeing is normal.bob wrote:When steaming the pump continuously runs and there is a good deal of water in the steam.
I'm pretty sure the pump is running 100% duty cycle.
When I had a BES800 it would run no more than 20% when using steam.
Also I'm getting over 50ml/min in water gain. Is that excessive?
Descaled 2x more times and it now runs correct duty cycle.
