BBcode - tables, [pre], [code] colours visual information
- happycat
I noticed some BBcode tags don't work.
Presenting information visually can make it easier to process.
For instance, if I want to compare several things, a table or matrix would be efficient.
I found that table, [pre] (preformatted text) codes don't seem to work
I found that
I found that
works as a workaround to capture spacing but defaults to a hard-to-read green font that I don't know how to change
Is this a policy issue? Are there some visual options other than using a photo of a table?
Thanks
LMWDP #603
- HB
- Admin
There is no [pre] tag defined in phpBB. The code tag works:
The green isn't hard to read on my display, but changing it to black is easy. Work for you?
Column A Column B Column C
1 2 3
4 5 6
- happycat (original poster)
Sure, black would be welcome. Thanks.
LMWDP #603
