Roast Vision - a new and affordable roast level sensor for $299 - Page 11
Read about current and future offerings from the site sponsors.
M0ohamed
#101: Post by M0ohamed »
Hi Zack, and all.
I used the same grind size for both of them, I didn't want to change any variable while testing.
You can check the video down here.
Regards,
Mohamed
espressovision (original poster)
Sponsor
#102: Post by espressovision (original poster) »
Hi Mohamed,
While it seems like a good idea to use the same grind size for both devices, unfortunately the CM100+ (and likely the CM200) requires a cupping style grind (70-75% passes through a US 20 sieve as described on the SCAA website). Lighttells does not explicitly state in their user manual that there is a grind size requirement, but I confirmed with them directly for the CM100+ that it is designed for a coarser grind.
Please repeat the measurements with the CM200 using the correct grind size for that device and then I can interpret the results.
Thanks,
Zach
