Flair Espresso news - Page 4
How much space do I need for the flair 58? Does it fit on a 40cm (15.7 inches) deep sideboard/ counter top?
From the pictures, and relating them to people shown near this machine, probably the biggest dimension being depth, then height 14", with lever down, then width 6".
Or, 51 cm x 36 cm x 15 cm
With lever up it seems to be as high as eyes level, when placed on a standard 72 cm desk, so beware to free space above...
Thank you for your answers. I also saw the dimensions on the website. I always have a problem interpreting these regardless of the product. It is always like, what number refers to height, width, length? And in this case, height with the lever up or not?
- Flair Espresso (original poster)
- Sponsor
Product itself is (in inches) 14L x 7.5W x 11.5H and with lever raised up, 24.25H and weighs 8 lbs. I see that the website was only showing packaging and shipped weight. We'll get on that. Thanks.derbrain wrote:How much space do I need for the flair 58? Does it fit on a 40cm (15.7 inches) deep sideboard/ counter top?
--Andrew
www.flairespresso.com
- Sponsor
Reviews of the Flair 58 are starting to drop in case anyone was interested in learning more from outside parties, or just want a chance to win one with no purchase necessary https://flairespresso.com/flair-giveaway/
--Andrew
- Sponsor
and another from this morning
--Andrew
- Brewzologist
Thanks for posting those reviews Andrew. I hope to see more tests on temp stability of the 58 like the one from Xris below. He rightly points out that any column of hot water will be hotter at the top vs bottom, and the plunger was out, and he apparently used a 3rd party PF when conducting his test. What I'd like to see is something similar from Flair in a contained group head with a probe (drilled in perhaps?) that gives a more precise graph of temp stability at different heat settings where external factors are more carefully controlled. Thanks.
- Sponsor
3rd party, all metal portafilter with the temp probe touching and therefore reading off the surface of the blind basket. I'm sure there will be more like this taken by others, and eventually time and resources permitting, we can oblige.
--Andrew
