Fellow news and information! - Page 17
Thanks, Nick. I gave this a try with the Mexico from Small Planes and got a drawdown right around 4:00. It's not perfect, but I think we're moving in the right direction; less of that "off" taste I've been getting (whether it's sour or bitter) and more balance. I'll try going finer and see what happens.fellowproducts wrote:I think you may be under extracting the larger brews. The lower on the dial you are with the Gen 2 burrs, the better the particle distribution is going to be. When I hear "sour" I think under extraction. For your larger brew tomorrow, try 1 click under 7 and see how the coffee turns out.
Typically when I dial in a coffee, I start coarse and then push finer until the coffee starts to taste astringent. Please give that a go and let me know how it works out.
Nick
Update: Did 25g/375ml with Verve Nueva Montana Natural on 6 and got a really nice cup with a 3:00 drawdown. Starting to crack the code, I think.
My seasoning beans arrived today. I'll take it slow and steady as you advised, but do you have any advice on what grind setting I should use for seasoning?
Thanks!
- Sponsor
When I season a grinder I usually go on the finer end. For Ode Gen 2, I'd suggest a 3.
Also, just to explain what's happening, at coarser settings you're probably getting a combination of underextraction and overextraction at similar draw down times. As you go finer on the dial, particle distribution gets much better, and the extraction is more even. With the Gen 2 burrs the main piece of feedback I was trying to tackle was "the burrs don't grind fine enough", so they were designed in a way to have their sweet spot a bit lower on the dial than some other designs. Hope your cups improve over time and you enjoy.
Nick
Nick
- Sponsor
I'm sorry, but I believe that SKU was discontinued.
Nick
Nick
Thanks, Nick. I'm definitely getting somewhere with the bigger brews; 6.2 seems to be right at or very close to the sweet spot for a couple of coffees I have from Tandem.fellowproducts wrote:When I season a grinder I usually go on the finer end. For Ode Gen 2, I'd suggest a 3.
Nick
I'm still struggling a bit to dial in for my smaller brews, though. How much (if any) adjustment do you recommend for different size brews?
- Sponsor
The smaller the brew, the finer you'll need to grind in order to match extraction levels. If you're at 6.2 for a larger batch, I would try going down to 5 for a smaller one and take it from there. Keep going finer until the coffee starts to have a lasting, dry astringency in the cup instead of a lingering sweetness.
Nick
Nick
Just wanted to pop in say that I think the Drops program is solid. I've tried a handful of coffees, and many more hits than misses compared to other "subscription" programs (Drops allows you to opt in each week, which is another awesome benefit).
The Rwanda from a couple of weeks ago was phenomenal.
https://fellowproducts.com/blogs/brew-t ... brew-guide
Second this. I look forward to that text every Tuesday and love being able to try out new (to me) roasters without having to order 3+ bags to get free shipping or make the shipping cost worth it.
- Sponsor
Happy Opus launch day! - https://fellowproducts.com/products/opus-coffee-grinder
There has been quite a bit of talk about this grinder. Just wanted to say that I'm here to answer any questions you have and help you learn about this product however possible.
Also, I made a video to help understand the inner ring, which you can check out here: http://www.youtube.com/watch?v=ZHjqeZ2lDkQ
Thanks for checking it out!
Nick
Nick
