Decent Espresso news - Page 131
- decent_espresso (original poster)
- Sponsor
DECENT GASKET REMOVAL TOOL
We've designed our own group head gasket removal tool.
We tested lots of gasket removal tools, but found that:
- the ends of most were too thick to easily insert along the side wall of the gasket.
- Or.... they were too fragile and the tool tip bent under use.
What we liked best, was a professional dental tool.
So we contact a dental tools manufacturer, and tried all the ends they sold.
We then made our own tool, with the two ends we liked the best.
DEEP DIVE ABOUT GROUP HEAD GASKETS
Paul and I did a "brain dump" of everything we know about espresso gaskets, and what you might like to know too.
I know, I know, a 22 minute video about the espresso gasket is a bit hard to believe.
But yeah, it turns out, there are lots of things to say about this very humble part.
The gasket video isn't targeted specifically at Decent Espresso customers. It's really just everything we know about gaskets, that you might find useful to know too.
http://decentespress.com/gasket
Hey John
On the vinyl wrap, I'm mostly curious if it will be a more cost effective way to do a single color update vs buying all of the external shell pieces. For example I've been thinking of changing my white XL to black or some other darker color. I'm sure there will be people who want to do custom graphics, but for me it would be a single color.
- Randy G.
I had an old evaporative cooler that looked like an electrolux vacuum cleaner. I used it on my '48 Chrysler. I rebuilt it and painted the exterior with brush-on hammertone paint. It was a spectacular look!
www.EspressoMyEspresso.com
* 22nd Anniversary 2000-2022 *
- Sponsor
an interesting discussion over here
Decent and next level of excellence
with people giving their wish-list for things they'd like changed on the Decent.
I thought I'd let the discussion run its course, and then give some of my thoughts. As a vendor, I am not allowed to post in the community forum, so I'm writing my thoughts here, where I am.
That's why we went with ceramic baking dishware, made by Loveramics.
Also, plastic ages terribly, and that's doubly so for clear plastic. It tends to get brittle or cloudy with just a few year's age, and that's not great for a water tank.
Ceramic, if you don't drop and break it, lasts forever and ages beautifully over the years.
Also, ceramic is resolutely high temperature dishwasher safe. I'm not sure if other espresso machines's plastic water tanks are.
However, we would like to:
1) lower the weight of our water vessels
2) make them stronger (ie, withstand dropping on the floor)
3) make the shape more consistent (shrinkage variation is a thing with ceramic)
To that end, we hope to be able to move to ceramic-coated, stamped aluminum.
These have the same food safety merits of solid ceramic, but:
1) they're lighter (often sold for camping)
2) much stronger
3) consistent shape, due to the inside stamped aluminum shape
The reason we haven't already moved to this, is that we haven't found a manufacturer who will tell us what's in their coating. They consider this to be a trade secret, and, to be blunt, we don't trust that.
So, if we manage to find a company who will be transparent with us about what they're doing, we'll move to this in the future. But, I'm not sure we'll succeed, in which case we'll stay with our current approach.
I realize that people like directly hooking up a boiler-based machine to water, but have you thought about the downside? You still have a water reservoir, but now it's the boiler, and you can't get in there to clean it.
For me, it's a major plus that the water reservoir in the Decent can be taken out and fully cleaned, unlike a boiler.
1) firstly, new profiles deserve a beta cycle, just like the app, so I don't want to release an experimental profile into general release.
2) secondly, there will be a better way to share profiles coming in an app upgrade.
As the discussion mentioned, your two machines are different models, separated by a few years, and yeah, they do have differences.
You can currently adjust temperature and flow rate of your steam (down to 0.4ml/s) which makes it fairly gentle, but on the DE1XXL, steaming a small 50ml of milk well is still difficult.
At the end of 2023, we'll start making coffee with it. I don't think it'll make its way into a public machine until 2024, though, because it's certain to have many issues, as it's a new invention (well, it exists in larger form for the oil industry, but nobody has downscaled the design before).
Stats are an interesting problem, because what is good for a cafe is not what a home user needs. Specifically, cafes want total consistency, and don't change much, so (say) a "shot times since the past 30 days" chart is quite useful in a cafe. At home, it's likely useless as we home baristas change beans, grinders, profiles, way too often.
Anyway, no matter, as data visualization is a huge passion of mine (hello Tufte!) and I do plan to spend quite a bit of time on this in the future.
A "one page" version of Insight is coming, which will also borrow (cough) some of the best ideas from MimojaCafe (ie, such as quick profile changing)
Nobody's mentioned it here, but a mobile-phone friendly version of the de1app is also coming.
1) is largely silent
2) knows exactly how much water has been moved
3) uses a different water mixing approach
But I am impressed by the UI on the Meticulous machine, and there are lessons for Decent there.
On the Diaspora user forum, there are a number of UI/UX professionals, drawing up ideas, but so far, nothing is a clear win. Everything has a compromise. For example, while the Meticulous UI supports direct-manipulation (very nice!) this comes at the cost of precision. They're quite good designers, so they might have a solution, but as a rule, all design is compromise.
What we're working on currently is making it easy to refill the water tank manually, without needing to take the lid off. Here's a video of a recent test of the latest revision. You can see that we have a "canal" that you can pour into, that then goes into the tank.
This part will be very low priced.
We will absolutely never use plastic for a water tank or drip tray. I don't want to ever think about water leaching.GDK wrote: 1. Lose the ceramic drip tray and make it from nice sturdy plastic. This would provide benefits:
a. easier operation/workflow:
- tray will not break easily while handling it
- it will be lighter
- it will slide in and out more smoothly (no need for tape)
b. less shape variation which should eliminate that imperfect fit and wiggle with the tray grid on top
c. there may be cost benefit (?)
2. Have a plastic water reservoir. Ceramic may be less susceptible to grime etc. but again the benefits of plastic outweigh that, adding a cover may become possible too.
2) much stronger
In June, we'll be releasing new group head inner parts, that reduce the headspace again some more, about to whatever Sheldon's lowest setting is. We're now following the E61 headspace standard.ShotClock wrote: 6 - Easier way of adjusting headspace. I use a spacer/dispersion block from Sheldon which is great. I believe that there is a new block incoming from decent which will address this soon. Would be great if this could be adjusted shot-to-shot, but I'm not sure if this is feasible.
That's not going to happen, because want the water reservoir to be cleanable.ShotClock wrote: 7 - A method of plumbing the machine that completely bypasses the reservoir. Currently, it looks like both refill and plumbing kits just refill the reservoir automatically. To avoid biofilm etc., it would be great to bypass the reservoir completely.
Two things on this:ShotClock wrote: 8 - Separating the update of profiles from the rest of the software would be a great addition. Currently, if you want to test the "80s espresso" low temperature profile (or any other experimental profile that decent is developing), you either need to move to a less stable build of the decent app, or download the profile via a third party app such as visualizer. Reducing the friction of trying new profiles would be a nice step in my opinion.
Using the same model and calibrating flow and pressure on them, to your location, will get you very, very close to having identical machines.Quester wrote:I've also never been able to get my two DE1s to behave similarly enough that the same grinder, bean, and recipe produces the same result. Lot's of work with calibration has helped, but they still behave differently. This would be unfortunate in a cafe setting. But John and others have done this a lot and not had any issues.
In our planned for 2024 "Bengle" model we'll likely move to a stainless steel drip tray, as it won't be visible like the ceramic is. We'll then be able to have a more robust tubing solution. The ceramic drip tray can't.Randy G. wrote: My only major thought in terms of such improvement would be to have the plumbed drip tray made so that it 'plugged into' the machine or had a simple quick-disconnect of some sort so that the hose did not interfere with the removal of drip tray so that the reservoir could be more easily accessed for removal and cleaning.
We're working on a "wattage divider" feature in the firmware, which can downgrade the higher power steam heaters so they are more gentle.GDK wrote:There is no such thing as too much steaming power on the DE1XXL. AFAIK, it will have a feature (FW upgrade in progress) where you can preprogram the power to match the typical quantities that you use - you have whatever you want, which is great and I do not believe any other machine has it!
We've been 2 years in R&D designing our own pump, which you can think of a "small auger". Internally it's called "RayPump" (guess who invented it).pizzaman383 wrote:How about positive displacement gear pumps instead of solonoid pumps so that they directly control flow instead of modeling flow.
Greater visualizer integration is in progress, and I'm working with Miha on that. You'll have each shot's visualizer chart viewable inside the de1app, and a click-on-it will move you to Chrome and the right webpage for that shot.luca wrote:Software - There is still ample room to improve the software.
-UI could do with a bit of a think through and a tidy up. It has a lot of functionality, but it's not very polished. I'd like bigger "power off" and "settings" buttons, for example, since I tap them a lot. In the insight skin, I'd love a one tap button to toggle between my two most frequently used profiles, since I usually start the day with an espresso and then the next coffee is a filter coffee. There are lots of things that probably would come up if I really thought about it.
-Visualiser is really a thing that Decent should build and maintain. It strikes me as something that has some features that are maybe OK, but not really a lot that renders it all that useful. Decent really needs a web enabled way to access your data and go through it, and an integrated way to take notes. There is just so, so much clunk factor in taking notes. Everything is so hard to do that I use a whiteboard to keep tabs on my grind setting, not the software.
-The software should really now be developing "shot improvement" features. By this I mean something like a stats package that shows you your rolling average of what the shot output is like. So it could compare AUC for your shot volumes against your rolling average and give you your standard deviation, to give you some actual stats about how good you are at making consistent shots. Decent had the market lead on the software platform for years, and squandered it a bit, so that there are now third party platforms and gadgets that people are retrofitting onto commercial machines to get stats and improve shot-to-shot consistency in their cafes. Decent keeps on saying that they want to be in cafes, and this was the clear killer feature that they could have built and had as a point of difference. It sort of builds on top of having an OK interface for inputting data, which Decent doesn't really have. It's kind of insane that Decent had the absolute best platform around to develop these features, but now if you're running a cafe, you can get these sorts of stats easily by retrofitting some stuff onto a Linea or whatever, but you can't actually even get them on Decent. So, crazily, Decent is now trailing its competitors on the software stuff in some respects.
InfamousTuba wrote:Wouldn't using a gear pump require a redesign of the water mixing? Or would they put 2 gear pumps in the machine and raise the cost of the pumps dramatically. I think eventually they will change the pump system but the redesign would take a long time
Yes, the RayPump:Pflunz wrote:Principally two gear pumps would work, but you have to change how you control the pumps (PWM instead of skipping pulses). Water mixing could be the same.
As far as I remember, John said there will be a new version of the decent with different hardware, with another water mixing solution. There will only be one gear pump with two outlets, and an additional motor in the pump will control the water ratio of those outlets. So that you only need one of those pumps.
I'm not sure how purple and grey bubbles along a line is a better user experience than a chart showing real data, with X and Y labelled axis, but you are free to disagree.yoshi005 wrote:The MARO is trying to surpass the Decent by its UX:
https://www.kickstarter.com/projects/ma ... so?lang=de
video
In 2023 we'll be releasing a silicone water tank lid. It's fairly rigid, unlike your stretchy design.mikelipino wrote: Like Luca above, I quite like the ceramic water tank. Both the water tank and the drip tray aren't as fragile as I initially thought. They feel just like any ceramic baking dish and are likely as durable. They certainly won't bounce if they hit a hardwood floor, but I also don't need to treat them delicately.
On the topic of a cover, I created a DIY cover from a silicone stretch food cover. The 185 mm x 185 mm cover fits nearly exactly, and is food safe, heat safe, and reusable. Just cut some holes for the water inlet and return and stretch over the water tank. Be sure that the water tank and stretch cover are bone dry (wet silicone slips, dry silicone clings) and it stays put.
I would use this cover if I were plumbed in to keep particulates out. Since I'm not currently plumbed in, it's more of a hassle to refill the tank so I've set it aside for if I get the catering kit. And my environment isn't particularly dusty nor spore-y, so a weekly wash of the tank hasn't been a huge deal.
- Sponsor
All DE1 v1.44 models now available
All the different Decent espresso machines are available in a v1.44 model.
https://decentespresso.com/new-in-v144.html
If you're paying in US Dollars, the price increase from v1.43 to v1.44 is only $100.
If you're paying in another currency, the v1.44 is quite a bit more expensive, because we've rebased the price the current exchange rates.
That makes that the remaining v1.43 and v1.42 models are at a much lower price, in non-US Dollar currencies, as the price remains based on the exchange rate from 1 to 2 years ago.
The 220V DE1PRO v1.43 is €587 less expensive, for instance.
Once we sell out of the older models, all our machines will be v1.44 models, priced at December 2022 exchange rates.
Also note that all the "models page" https://decentespresso.com/model all v1.44 models are now displayed with a 360º rotation movie of the real machine. We're no longer using renders, since we've worked at getting the photographic expertise to show you 360º videos of our machines that look good. They're all using youtube, so they load quickly too.
For example:
For example:
- Sponsor
I've posted it before (maybe a year back) but in the past year, I had three goals:John, you're obviously very transparent about your business. Any possibility of sharing your feature backlog and roadmap?
- make the de1app quite stable (that was two versions back)
- get rid of the main annoyances in the de1app (that was the most recent version)
- for the next version, the main goal is implementing CafeHub so that
- the app fully functions on all OSes,
- can be used as a web app
- can add more bluetooth devices (such as the MEATER bluetooth scale) reliably
- can start to host Javascript based app components
- simplifying the internals, to increase reliability, simplify the supply chain, increase performance
- Supply chain reliability is a huge problem.
- For example: our valve and pump supplier ODE (an Italian company), is also a car switch manufacturer and has been sold to a bigger company.
- They are now not so interested in espresso anymore, so this is causing a lot of work, as our Ultem parts, and integrated valves, are all made by them.
- the group head is going to stainless steel on top, and plastic inside, to remove lead issues, and increase coffee quality with better temperature measurements
- a new Decent machine model, for end-of-2023 release, that will have an integrated scale
- We've been working on a new pump and and new water mixing approach for two years already, and it still has another 2 years to go before it can be widely used.
- I don't want to make that public at the moment, as it shows too much and is not organized or presentable, either.
- But know that I write down every reasonably-presented idea presented here, into this large todo, and each gets an "impact" and "effort" score.
Each de1app version gets a "major concept" applied to it.
- For the de1app, that's been (in release order) "stable", "less annoying", "cross platform", "web app".
- And some number of small things from that TODO list
- As well as things that other collaborators do (such as support for new bluetooth scales, or background firmware updating)
- Sponsor
BETA de1app released (v1.14.1.27)
There have been some important bug fixes, and some minor features, added to the de1app in the past 10 weeks since v1.41 was released.
I've changed the app's designation to BETA, so it can get wider testing and to move to soon to being the new STABLE version of the de1app.
More info about this beta release at:
https://public.3.basecamp.com/p/fpyARvx ... N8am3YVUvA
Here's how you can try the BETA version:
https://public.3.basecamp.com/p/w5vFUf6 ... CSZ7VPRjVH
New features:
New features:
- New 80s Espresso profile added, a low temperature approach specifically optimized for medium to dark roasted beans, going from 80ºC to 72ºC. The goal is to increase the complexity of the espresso, without over extracting and getting unpleasant dark roasted flavors mixed in.
- New Extractamundo Dos! Profile by JoeD added
- New "Change Beverage Type" feature added to Advanced Profiles
- Catalan and Austrian German languages added
- A "Steam Only" profile was added, which keeps the hot water heater off, for when you only want to use the steamer, and not make coffee.
- "Eco-steam" option lowers idle power consumption by 20%.
- It brings your steam heater temperature down to 135ºC after 10 minutes of your machine being hot and idle.
- The steam heater will rise to your requested temperature as soon as you do anything (make espresso, touch tablet)
- And so, for most people, there is no downside to enabling this feature
- Smart Espresso Profiler released a new APK that works with the current DE1 firmware
- New Acaia scale firmware could cause an error message in the de1app.
- Background firmware updating by Johanna was in the NIGHTLY version but is not yet bug-free, so it was removed for now and will come back in the next NIGHTLY version.
- Sponsor
New Decent video : Tamping is difficult
I'm working at replacing the videos on the Decent Espresso website that are old, or that I'm embarrassed of :-O
On our Decent Tamper page https://decentespresso.com/tamper the featured video (Two Tampers Compared) is one I made 4 years ago. It's not bad, I worked hard on it, but it features two tamper models that we don't sell anymore (v2 and v3).
I've now totally gotten on board with self-leveling tampers and don't want to sell any tamper that doesn't.
Today we've released a new video about our v4 tamper, which aims to quickly explain why tamping without a leveling plate is quite difficult, and thus why you should get a tamper that does this for you.
While I like the production quality of the video (the set, lighting, video quality) I'm not so happy with the kinda-low energy level, and the laying out of the explanation, I think, could be clearer. But... it's an improvement over the previous video, if for no other reason than it features a current model that we actually sell!
We have quite a few filmed videos in the pipeline, and we're focussing on editing and releasing those now. Once the pipeline is "all dried up", we'll take another pass through the video we have released, and see which we think we should try to again, but better.
-john
-john
Currently the "Low Cost Model" is the DEpro. Is the DE+ no longer offered or is it temporarily not offered due to capacity and inventory choices.
Thank you
Thank you
