Custom Wood for your Espresso Machine - Page 27
- cannonfodder (original poster)
If you are looking for the pistons (stainless steel portion) you can order them from RegBarber.com and espressoparts.com.mavrick1903 wrote:Dave, I wonder if you wouldn't mind sharing the source for the tamper heads? I too am a wood worker, and while I would not be interested in production, nor would I dream of competing (your work is well above my own), as a fellow IT guy I like to make stuff and would like to make a tamper and PF handle for my Silvia.
Finished up a few more things. There is a set of Macassar ebony in the background, two portafilter handles, lever handle and steam knob in maple for an Elektra Leva and a very long muddler in a presentation grade curly maple with a Macassar Ebony cap. The muddler is still wet with the oil, it will get a nice satin sheen.
I have had a lot of requests for ECM machines. Unfortunately they use a non compression, two part, screw in steam/water valve that most commercial machines use. I could not get the inserts but finally had someone willing to do sacrifice a set of controls. So we whacked them in half to get the brass inserts out. Then I did a lot of Forstner bit, drill press voodoo and made a set. The caps are are a friction fit to cover the face and are counter drilled to hollow out the backs, along with the back of the controls. I still have to put an O ring on the insert to hold them fast but there is the first set. He also wanted a more traditional shaped set of portafilter handles. The second set handles are for another order. All are in cocobolo.
- mhoy
There is something about these particular pictures that stand out from the others. Perhaps the light, camera, I don't know, something special.cannonfodder wrote:Some nice Ironwood burl for a VBM and a Macassar Ebony catch tray for a Nino grinder.
Mark
