Custom Wood for your Espresso Machine - Page 162
- cannonfodder (original poster)
Thanks! Fits perfectly and looks very nice.cannonfodder wrote:Decent Espresso portafilter handle in Walnut.
Hey everyone, when getting a custom portafilter handle, is it usually easy to remove the old handle from the portafilter? I am looking to buy a bottomless portafilter and immediately put a new handle on it, but every supplier says the handles are secured to the body with loctite and will likely break the threads on the body if removed.
I found this generic handle-less body, but I'd rather buy one that I know will fit my Lelit Mara X.
https://www.espressocare.com/products/i ... -body-only
Thanks!
P.S. First post after lurking for a few months!
Thanks!
Finally took the opportunity to snap a couple photos of my setup and the beautiful work Dave did earlier this year.
Due to a few issues, Dave was rad enough to retool some pieces, upon our discovery that WLL and/or Profitec had made some design changes. I was happy to wait and I think you can see the end result was worth it.
Second and third photos show the hot water and steam knobbery without the typical Profitec chrome plated insert. Due to the slimmer nature of the wood knobs, I tend to think they look better naked.
They are on with Loctite, however Loctite breaks down at around 300F. Put the portafilter head over a gas burner on low and let it heat for a few moments. Once it is good and hot grab the portafilter head with a couple potholders and twist the handle. It will let go and unscrew.lancets wrote: but every supplier says the handles are secured to the body with loctite and will likely break the threads on the body if removed.
You're a life saver! Is there any reason to buy the brand name portafilter over a generic one, other than fin size? I could buy this handleless one for $50, or the branded portafilter for $80. I guess the body may look a bit more polished in the branded version.
