Macassar Ebony portafilter and group head handle for a Decent Espresso machine along with 4 feet, base, tumbler holder, portafilter holder, and coffee scoop for a Niche Zero grinder.
This one took a while. The owner wanted a shelf to hold his Lyn Weber Bean Cellar tubes. The problem was finding a way of mounting the thin shelf to the wall since you cannot have supports under it and a simple hanger would not hold. Went with a special floating shelf bracket machined from aluminum. It will give the shelf a floating appearance once mounted to the wall. That bracket is rated for near 100 pounds so holding a 3-pound shelf and coffee beans should be no issue. Also 2 portafilter handles and one machine handle for a Decent Espresso, Niche Zero grinder base, tumbler holder, and 4 feet all in a gloss finished Macassar Ebony.
