Water Lever Sight Glass Gaskets for Olympia Express
Hello everyone,
I'm having a difficulty with changing the gasket for the water level sight glass on an Olympia Express (may be V1.4). I was trying to use the same gaskets from La Pavoni but they don't fit so can someone advise me where to buy these gaskets?
My machine is the same as following:
http://www.francescoceccarelli.eu/Macch ... a_4325.jpg
Many thanks!
Hieu Cao
Many thanks!
Hieu Cao
Brewing coffee on La Pavoni is brewing with feeling and emotion, right?
- drgary
That early Olympia Express Cremina was based on an early La Pavoni. The answer to your question exists on Francesco's site here. (Please note that Francesco has not implemented https, so that your browser may tell you the sight is unsafe. So far, no problems here.):
http://www.francescoceccarelli.eu/La_Pa ... 60_eng.htm
He writes that you need to replace the sightglass with a later one that works with the seals that are now available.
Your machine looks like it is based on v1.3 of the La Pavoni Europiccola.
http://www.francescoceccarelli.eu/La_Pa ... 53_eng.htm
Your Cremina (a very nice, collectible machine) is a version 1.2 according to his site.
For maintaining early Creminas, his site refers you to maintainence for the early La Pavoni.
http://www.francescoceccarelli.eu/Faida ... lympia.htm
LMWDP#308
LMWDP#308
Thanks!
I've tried similar gaskets for later models that I bought these gaskets from coffee-sensor but it still doesn't fit!
I will try as advised:
Rgds,
Rgds,
