VAM Caravel v1 microswitch
- cuppajoe
Greetings -
I'm looking for a source for the microswitch used in the v1 VAM Caravel. Have so far whiled away a couple hours online with no luck.
Any help appreciated.
David - LMWDP 448
- dumpshot
I have a fried one as well. Never had any luck locating one and finally gave up.
Pete
Pete
LMWDP #484
- drgary
I would think anything the right size that makes contact would work and wonder what can be retrofitted from microswitches made for pressurestats, for instance.
LMWDP#308
LMWDP#308
- cuppajoe (original poster)
Hi Gary -
That's plan B. The trick is going to be finding something not only close to the size, but with the mounting holes in the right place with proper spacing. Kluging something is always available, but as you know, the Caravel's thermostat system is a marvel of over-engineering. Not only is it complicated, but the adjustments are rather limited in range as well. Wanted to avoid having to make invasive mods.
David - LMWDP 448
- drgary
Can you show us a photo of the switch with measurements? It'll help others visualize the challenge.
LMWDP#308
LMWDP#308
Here's the switch installed -
And the switch -
Assembled, the case is 29.75mmL X 18.2H X 11.45W. The mounting holes are 22.2mm on center.The spring tab with the contact and is riveted to the S bracket has deconstructed. I'm also exploring trying to kludge a different contact spring in there. Unfortunately there are no manufacturing marks on it. A modern replacement would probably be better.
This thing drove me nuts for several days. It is a normal off switch and the Caravel requires a normal on for the machine to function, so was never powering on. As the switch looked like it could be assembled to work either way, I attempted to reassemble it correctly.
And the switch -
David - LMWDP 448
- crazy4espresso
My 110v element recently gave out right about the same time my microswitch went. I theorize the microswitch issue had something to do with the short life span of my element? I don't believe these switches are rated for the higher amperage of operating at 110v. I would like an suitable replacement before I buy another element. I'm glad someone started this thread.
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
cuppajoe wrote:Here's the switch installed -
<image>
That looks a lot like the grinder shutoff microswitch from my DRM 68. Let me see if I can lay my hands on it and take measurements. I had noticed this before but never wanted to pull my v1 microswitch :/
LMWDP #411
- crazy4espresso
The mounting holes are not on a diagonal though, on the VAM/Caravel. They're on the same side.
LMWDP #427
LMWDP #427
