User Experience with the Strietman CT2 - Page 79
I almost exclusively use the 15gr basket. For dark roasts 13,5-14gr, medium and lighter roasts will do 14,5-15,5 depending on roast level and bean type. If the top of the tamper base falls under the basket rim you're good in terms of headspace for the 15gr basket.
Looks like an Aeropress metal filter...jley08 wrote:
Puck screen that's incredibly thin and easy to clean by sworksdesgin
Looks really nice. I just ordered two of them as shiping was more expensive then one of them. No more cutting up aeropress filters which I've been doing for years.jley08 wrote:image
- Hudson
I finally decided to purchase a pressure gauge last night. I'm excited to receive and find out what pressure I actually pull my shots at.
Those who are using a gauge, is there a specific profile you use in general? I'm planning on starting with a spring-lever profile.
LMWDP #534
Does anyone know if there is a smaller basket that would fit this machine? My girlfriend says the 15g basket is too strong for her lattes. I was thinking like a 9-12g?
- truemagellen
Just under dose for now. Yes I will end up with a watery puck. There are much smaller baskets down to 7g if u like. Look at Cremina or Elektra baskets.
Ya I just noticed with under-dosing, there is very little pressure which I'm sure means channeling.
- truemagellen
A grind adjustment will be needed for lowering the dose since there is less resistance.
You can also use a puck screen or paper filter to reduce the messy puck and pour off the excess water after the shot. A sintered stainless puck screen will take up headspace too when you are under dosing.
I normally dose between 10-12g in the 15g basket with no issues. Finer grind is definitely needed and puck will be watery but really not a big issue. Also I use the thin puck screens from Tudor (Coffee Sensor) on top of the puckZybane wrote:Does anyone know if there is a smaller basket that would fit this machine? My girlfriend says the 15g basket is too strong for her lattes. I was thinking like a 9-12g?
