User Experience: Flair Espresso Manual Lever - Page 90
It was 95 degrees celsius or 203 farenheit.shotwell wrote:After preheating and adding water can you introduce an instant read thermometer to the cylinder before inserting the piston? Having an idea of a starting brew temperature would help me to diagnose.
You certainly seem to be getting hot enough to work with most anything. Any chance you can put together a video of your process or describe it thoroughly? I found that my flair method needs a surprisingly long preinfusion+shot time to avoid sourness for medium light/light roasts.
Sour might mean underextraction rather than low temperature. I'd suggest the problem is mainly your grinder. And probably too large a dose. Poor grind and too much coffee makes underextracted, sour shots more likely.
I'm looking into acquiring a hiku grinder. But in the meantime, would how much would you suggest i dose instead?
Thank you!
Thank you!
Would not recommend the Hiku if your purpose is for espresso. It requires quite alot of strength to grip and turn, especially light to medium roast
Oh i was offered a used one at $150AUD so i thought it was a pretty decent price.
I've had success at 16g with the coffee I use, but I know others dose lower, like 12g. While the Flair needs a coarser grind than a typical espresso machine, remember that you will need to grind a bit finer as you reduce the dose. Experiment to find a dose that works well with your coffee. But I wouldn't expect much better results until you get a better grinder. I use a Helor 101.melkenshawn wrote:how much would you suggest i dose instead?
I think people may still use the Lido 2 for espresso, but it wasn't designed for it. Perhaps someone else can tell you how well it works. The Lido E is the espresso version of the Lido, with finer adjustment than the Lido 2. If you want to make espresso, my advice is to get a grinder designed for espresso. Search the Grinder forum, there are discussions about pretty much every hand grinder on the market.
I'm using Lido 3 (similar construction like Lido 2, different burrs) and Feldgrind. Both work reasonably well, though not ideal. Problem with Lido 2/3 is adjusting mechanism which has too much tolerance/free play in the threads, which can be solved by "teflon tape" tweak
