Upscale Home Based Lever Machines - Page 3
- Supporter
- bostonbuzz
There are a few threads about pid'ing the group head of the Strega which I did. I put a dimmer on the pump which is less than ideal since the element turning on and off changes the dimmer setting. Fitting a pressure gauge isn't straight forward either. For the same budget today I'd probably go for a pump machine with no-flush PID temp control and stock pre infusion adjustability. Or a "more metal" machine like the Londinium that can also be modified. I don't like the plastic handles and the plastic group top of my Strega.
I've been looking at slayers, strata mp, etc.
I have other wants in a machine that still doesn't exist... first world problems.
LMWDP #353
I'm not sure if this machine was mentioned. The Nurri Leva sa. is built for commercial use but has interesting options that would make it an exceptional device for the home barista if there were the space. And would have the ability to produce 100 espressos with ease each day with its mult-boiler PID system
Nurri Leva S. A.
Nurri Leva S. A.
- rolex
Ah, the Leva SA is meant for commercial? I am interested in a lever machine for home use and this was on my radar
- Supporter
The Leva SA looks nice but is above my price range.
David
No. It has only 1 PID, which uses the same P.I.D parameters to control 3 different temperatures (2 boilers and 1 grouphead), and the steam boiler heater is only 1000W, so the steam pressure decreases quickly and needs more time to recover.rolex wrote:Ah, the Leva SA is meant for commercial? I am interested in a lever machine for home use and this was on my radar
- Supporter
As I continue my research, the updated Profitec Pro 800 appears to have several features that differentiate it from the Bezzera Strega. I'll check out the HB forum threads, but am surprised the 800 did not receive more support in this thread.
David
- baldheadracing
Perhaps the Pro 800 didn't receive more support because you said:KanzaKruzer wrote:As I continue my research, the updated Profitec Pro 800 appears to have several features that differentiate it from the Bezzera Strega. I'll check out the HB forum threads, but am surprised the 800 did not receive more support in this thread.
... which implies:KanzaKruzer wrote:... prefer light or medium roast beans.
Satchmo780 wrote:Out of the options selected, the R24 or the Strega give most control for parameters you care about for light roasts.
The ACS Vesuvio Evo Leva should also be in the discussion.
