Tips for removing La Pavoni old style boiler flange?
I have the 2 hole boiler flange and cannot get it to budge with any DIY methods. I see there are tools to buy and rent but they all appear to be for the 3 hole flange version. Any tips?
I have one of these to remove as well. I was going to make a tool but something like this might be a good option.
http://www.ebay.com/itm/ADJUSTABLE-FACE ... 1068919453
- drgary
Larry,
That's an elegant solution. Thank you. On your suggestion I've ordered a copy of Shop Class as Soulcraft.
LMWDP#308
LMWDP#308
P.S. On second thought I do not think the pin spanner I linked to will work.
L-
L-
- drgary
Have you tried giving it a few sharp taps around the rim to encourage penetration and loosen hard gaskets or crusty residue? Also wiping away excess oil and applying moderate heat could help.
LMWDP#308
LMWDP#308
- civ
Very elegant indeed.drgary wrote:That's an elegant solution.
Excellent. =-)
toddmp wrote: ...same thing on my workbench but I just cannot get the flange to budge.
To thread a blind hole is tricky enough and on top of that brass can deform easily.
Could it be that the tap or the screws have caused a bulging underneath where the holes are and that it this what is keeping the piece from turning by making pressure on the base?
Just a thought.
Cheers,
CIV
The flange holes are actually drilled all the way through so it shouldn't exert too much pressure unless the bolts were screwed in tight against the base.
How much force are you able to exert? I used quite a bit...enough to bend the bolts slightly. I imagine one could screw in the bolt and then use a hammer and drift punch to tap it loose as well.
May the force be with you.
Excellent!drgary wrote:On your suggestion I've ordered a copy of Shop Class as Soulcraft.
- drgary
That approach has worked for me, hammering the end of the wrench once you've made sure you've got a good insertion and grip.perfectwheels wrote: I imagine one could screw in the bolt and then use a hammer and drift punch to tap it loose as well.
LMWDP#308
LMWDP#308
