Temperature gauge into the HX path of a Commercial Lever - Page 3
- naked-portafilter
You have every freedom with a spring lever. Playing with different pre-infusion and pressure profiles. The profile of the spring is only one option. If you have the gauge you will exactly know what's happening. Of course you don't need the gauge for that freedom. You can also do experiments without it.FotonDrv wrote:I am sure i would be surprised about the pressure readings but what good would they be if i cannot change the pressure?
If I had the ability to vary the pressure thenthe pressure gauge would be a big help
- pizzaman383
- Supporter ❤
I have found that I get a good temperature reading off the group head near the location you are talking about putting a probe in the water path.
Here is a post that illustrates my probe:
Temperature Management on Dipper Levers
I put temperature conducting grease between the thermocouple and the group head plus thick Teflon between the thermocouple and the clamp. There is a few second lag but it works well enough for my purposes.
Curtis
LMWDP #551
LMWDP #551
- FotonDrv (original poster)
Yes, that measures the outside of the group temps, I am trying to measure the actual water running through the Group. Being that this is a cold fed HX there will be a noticeable temp drop when the shot is pulled because new cold water is entering. I have zero idea of how much water the HX holds but it looks like it could be more than just shot water.
- naked-portafilter
That looks like it is going to measure the temperature of the rod and linkage.
- naked-portafilter
That was just a wire. Sensors I use measure at the tip.
That is a real engineering feat to get that wire around those corners.
When do you think you will have that product ready for sale?
- naked-portafilter
I hope I can make working proto-type in the next two weeks.
- naked-portafilter
