Strietman CT1 lever pin
RockyIII
Postby RockyIII » Apr 04, 2017, 4:40 pm
Has anybody found a stock screw apart lever pin that fits the CT1? It would be easier than dealing with an E-clip every time I perform maintenance on the machine.
Rocky
redbone
Postby redbone » Apr 04, 2017, 5:24 pm
Depending on size you may be able to use the set made for the La Pavoni or Cremina levers.
ON A QUEST FOR BETTER ESPRESSO
Rob
LMWDP #549
CwD
Postby CwD » Apr 04, 2017, 5:35 pm
I got a special E clip tool for the CT1 and it helps a ton. Not perfect, but if you can't find a pin that comes off easier it's another option.
RockyIII
Postby RockyIII » Apr 04, 2017, 6:23 pm
redbone wrote:Depending on size you may be able to use the set made for the La Pavoni or Cremina levers.
The brass lever pin on the CT1 measures 6mm OD x 18mm LG. I have not seen the dimensions of the The La Pavoni and Cremina lever pins, but they do not appear to be the same size.
Rocky
RockyIII
Postby RockyIII » Apr 04, 2017, 6:25 pm
CwD wrote:I got a special E clip tool for the CT1 and it helps a ton. Not perfect, but if you can't find a pin that comes off easier it's another option.
I have a tool, but I still worry about the E-clip taking off as well as the possibility of scratching the lever.
Rocky
DrNik
Postby DrNik » Apr 04, 2017, 6:40 pm
Assuming the assembly is the same as an ES3 (which I believe is identical as far as lever attachment): just leave the E clip off? I've been using the machine for over 2 years now, with just a single side "clipped". In operation, the pin doesn't move and makes removing the piston a breeze...
Just my 2cts... ;)
cheers
Nik.
John49
Postby John49 replying to DrNik » Apr 04, 2017, 6:56 pm
Brilliant!
RockyIII
Postby RockyIII » Apr 04, 2017, 7:54 pm
DrNik wrote:Assuming the assembly is the same as an ES3 (which I believe is identical as far as lever attachment): just leave the E clip off? I've been using the machine for over 2 years now, with just a single side "clipped". In operation, the pin doesn't move and makes removing the piston a breeze...
Just my 2cts... ;)
cheers
Nik.
Heh. I used mine like that for a week or so but decided it might not be the safest thing to do. Maybe I will try it again.
Rocky
wachuko
Postby wachuko » Apr 04, 2017, 8:03 pm
RockyIII wrote:The brass lever pin on the CT1 measures 6mm OD x 18mm LG. I have not seen the dimensions of the The La Pavoni and Cremina lever pins, but they do not appear to be the same size.
Rocky
6 mm OD
23.7 mm inside width
Searching for that perfect espresso!
Wachuko
RockyIII
Postby RockyIII » Apr 04, 2017, 8:40 pm
Jaime,
Where did you get that pin?
Rocky
Sponsored by intelligentsiacoffee.com
www.intelligentsiacoffee.com: home of the black cat project
