For the force adjustment, what day meant was certainly that it is direct lever rather than a spring lever...
It seems that the new counter-top machine is very close to the wall-mounted ES3 (nice evolution since the first version, that was pretty much a redesigned Caravel).
*Edit: here it is...
«The ES3 features two 320 Watt heating elements integrated in the brew group for ultimate thermal conduction and heat build up. Cold water can be poured in the copper funnel on top, it will subsequently heat up. The red light indicates when it reached brew temperature. The temperature of the water is controlled by means of an adjustable thermostat working within a 4 degrees differential.»
