Starting of new IZZO Pompei - Page 2
ok, thanksNick111 wrote:image
This is the pump cable.I just don use it.
Try it and see what you like. You have to drink the coffee. Nobody can tell you at what temperature the espresso is to your liking but you.Alex-G wrote:I remembered this recommendation in my head
if i find this then surely posted here
how much do you recommend?
- JohnB.
1.1-1.2 bar is a pretty standard setting for any of the lever machines using the same style group as the Bosco. I don't see why the LSM group would require a higher setting. As I recall Bosco ships them set to 1.5 bar which is way too hot but maybe that's what they like in the Italian cafes. It will depend on the coffees you are using so try it at the lower setting & the turn it up & see which you prefer.Alex-G wrote:I read the recommendations of 1.05-1.2 bar, is it worth trying 1.5 for a start?
maybe immediately lower? is there a screw? how much to twist?
LMWDP 267
hahahaha... wow! The difference in size makes one look so small and the other machine huge!!!
Congratulations!!
Congratulations!!
Searching for that perfect espresso!
Wachuko - LMWDP #654
- JohnB.
Surprised that you still have the Strega. Still use it?
LMWDP 267
