As part of learning how to use my La Pavoni Europiccola I have occasionally ended up with too fine a grind and/or too hard a tamp.
Today was 15g at 50 seconds with high pressure on the lever, and it was an amazing shot.
Has anyone else had this experience?
Slow pull - 1 minute - excellent?
I don't have a Europiccola, but on both my Robot and my LaPepina I have definitely found that sometimes a finer grind a longer shot time is what gets the best results. As long as you avoid overheating or channeling, a fine grind and a long pull will give you better extraction, which often equals better flavor especially for light coffee. if it tastes good, its good!
My best shot this morning was from a ~50s shot (20s preinfusion/soak), between 4 and 8.5 bar. Caffe Lusso's Ethiopia Sidama. 15g in 35g out. Came out sweet and fruity with a tiny bit of astringency.
From what I've read, this is a fairly common brew recipe for light roasts. I think Scott Rao (and others I'm sure) does an even more exaggerated version of this with a very long PI and maxing ~7 bar on a very long shot.
Really good to know!
Yes, this is a lighter roast. If I don't have channeling it's unreal how good it is.
Yep, I've pulled some fantastic shots of lighter roasts on a Pavoni and other levers in that range.
- EddyQ
My guess is that your brew temperature was a little low for perhaps a light roasted dense bean. With lower temperatures you would need a longer brew time for the same extraction. Do you monitor your group temperature? Maybe try increasing it a bit while coarsening up you grind for a 30-35s pull.espressed wrote:Today was 15g at 50 seconds with high pressure on the lever, and it was an amazing shot.
LMWDP #671
- Almico
- Supporter ★
My best shot to date was from my LaPavoni Pro. My 1,000 worst shots were from the same machine.
- EddyQ
I think that is why the La Pavoni is such a great, fun machine to learn on. I share that experience, with exception of the worst of the worst which came from the KVDW the first week I owned it. I didn't know a shot could be that sour or bitter.
LMWDP #671
- guijan12
I don't mind the time when pulling a shot from my LPP.
Grind, grouphead temperature and ratio are the important factors I tweak with to get the best tasting espresso.
And as Almico already wrote; my best and worst shots are from the same machine (but not a 1,000 to 1)
Regards,
Guido
Guido
