SAMA Club espresso machine - Page 9
- redbone (original poster)
Sweet! One of my gripes is the shallow stock baskets. What is your shot volume?redbone wrote:Switched to the latest Elektra Micro Casa a Leva (Mcal) deep baskets. Only use the oem baskets during the pre-heat phase to add resistance to the PF during blank shot heat up.
I'm going to add a vac breaker to ease the initial heat up vac lock.
Using the deep MCaL basket 17-17.5g of coffee. I vary the output volume depending on coffee used and espresso vs espresso for Americano, Cappuccino etc.. From 1.2x-1.8x output.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Woo Hoo, you maybe saved my Lusso from a different home.
- IamOiman
I love the MCAL basket. I purchased a 46.7mm Strietman basket with a tamper, but I slowly went back to the MCAL. I use that basket in both my Pavoni and MCAL for great results.
-Ryan
LMWDP #612
LMWDP #612
Good to hear.pcofftenyo wrote:Woo Hoo, you maybe saved my Lusso from a different home.
Enjoyed working on it and learning its idiosyncrasies. Easy and consistent machine.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Now if I can find 1 place for all my parts I'd be in business.
I want to upgrade from the cruddy Ma-Ter pstat, piston gasket set, group gasket, shower screen, thermal safety, the spiffy MCaL PF basket, and vac breaker. Nobody that I've come across carries all. Ideas?
- IamOiman
lamacchinadelcaffe has parts for the lusso (and other home levers). While no longer under the name SAMA, pontevecchio produces the same stuff stillpcofftenyo wrote:Now if I can find 1 place for all my parts I'd be in business.
https://www.lamacchinadelcaffe.com/pontevecchio.html
-Ryan
LMWDP #612
LMWDP #612
* P-stat same as MCaL or PV Lusso. Ma-Ter 110 model.pcofftenyo wrote:Now if I can find 1 place for all my parts I'd be in business.
* Piston gasket set, and shower screen same as MCaL. Used a pre millennium LP Europiccola shower screen gasket for better fit.
* Thermal safety. My machine did not come with one but one could be added. It did come with a safety OPV valve on boiler. Fully dismantled soaked and cleaned the original one.
* Vacuum breaker. My machine did not come with one. Could be added to modified boiler cap.
As stated above https://www.lamacchinadelcaffe.com/ carries parts for Ponte Vecchio Lusso as well as Elektra MCaL.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
