SAMA Club espresso machine - Page 5
- redbone (original poster)
Older gents that I get my sand blasting and powder coating done were busy this week as it was a short work week here due to Monday being a holiday. Passed by to see them as they are very close to where I work. Let them know that I'd be away next week and not able to pick up until the following week. Like chatting with them and listening their strong Scottish rhotic accent and the fact that the older brother is a jolly sort. Decided to keep similar colour as new with black frame and fire engine red body. Did see frame on table painted in grey primer.
Received 2lbs of anhydrous citric acid via Amazon. Cheaper than buying direct from local retail bulk store. The 2lbs size price was the sweet spot. Tired of buying a few ounces from the grocery store at inflated prices. Made a stronger than normal mix 3 tbl to 1 liter of warm water to deal with heavy layered mineral sediment. Will leave overnight and rotate boiler to make contact with other side tomorrow morning.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
I'm confused... the end caps of the boiler look to be welded on. How do you get the dremel bits inside a welded up cylinder?jwCrema wrote:I am really thrilled to see you put your magic on this machine.
I spent days using citric acid to descale my Club's boiler only to determine the process might take an indeterminate amount of time. I have a higher end Dremel and bought a collection of sanding implements to mow through the deposits.
Although I know you know, but for others I turned down the rpm's on the Dremel to match the particular thing I used. This makes removal proceed at the right pace with the bonus that I had no "oh no!" moments.
I really wanted to do a pure chemical removal, but was extremely happy with a combination approach.
It's quite striking to see the parallels of a SAMA Club with my beloved Olympia Express Club. The SAMA seems like a simplified OE Club, although my Club has no channeling issues at all. Is it possible there is a missing part in the group head?
- Supporter ❤
Mahalo Walt.
When I looked at post #7, I thought I was looking into the boiler. The OE Club has a removal plate to the boiler which I see now the SAMA doesn't. As a result, adding mechanical removal via Dremel to the mix is not possible.
Ah, thanks for that clarification, Jack. So yours looks something like a Lambro, then, one side is bolted up? Those are neat...
- IamOiman
The Frame and body look pretty nice now. I expect updates on the completed machine once those parts arrive!
-Ryan
LMWDP #612
LMWDP #612
Is it the angle or the front plate of is black as well?redbone wrote:Frame and cover media blasted and powder coated similar to original.
Just waiting on parts from Ponte Vecchio in order to start assembly. International mail taking longer than expected.
<image>
Did you do anything to the drip tray and cup warmer?
Im asking because i might getting it repainted. But im hesitant cause my local powder coat guy only has ferrari red. And no other shades of red.
Front plate was cleaned on the front side and polished with some light cream abrasive and water. On back I cleaned with water and fine steel wool.
The cup warmer and drip tray were soaked and cleaned since they are not painted being stainless I believe. Nothing wrong with Ferrari red. Like to see when completed.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- IamOiman
Oof,redbone wrote:The anticipation on parts arrival is a killer.
<image>
Poste Italiane can be hit or miss. When I order parts from my preferred vendor they use DHL, and their shipping was consistently 2-3 days to the States from Italy!
Have patience!
-Ryan
LMWDP #612
LMWDP #612
