Repeatedly blowing thermal fuses on La Pavoni Europiccola converted from 220V - Page 2
- kowalej
Are you using the correct fuse? I know there are a couple different temp ratings available on the market for Pavoni fuses.
I think so, but I've reordered the same fuse a few times now so that could be the issue. I think I'm just going to convert to a fuse that can be reset. Is there any issue with replacing the consumable fuse with one like this?
https://www.theespressoshop.co.uk/en/La ... -2244.aspx
