Profitec Pro 800 Lever Grinding - Page 2
- pizzaman383
- Supporter ❤
The original Victoria Arduino Athena Leva group I obtained only showed minor marking through four years of daily use. One time during my group modification experimentation I managed to knock the ring which caused rubbing between several parts. The condor group replacement parts I purchased were not perfect and needed minor modification to eliminate rubbing.
Curtis
LMWDP #551
LMWDP #551
- kowalej (original poster)
I'm assuming you are referring to this part:pizzaman383 wrote:I have seen a fair bit of variation in the brass group parts. In addition, the brass ring loop can be deformed by rough handling. I have needed to tap and file the ring to eliminate rubbing.
If it was warped, it would influence the way the fork of the handle sits within the group housing.
I've owned two and have never experienced it with either of themdrH wrote:Does this happen to Londinium owners?
- pizzaman383
- Supporter ❤
Correctkowalej wrote:I'm assuming you are referring to this part:
Curtis
LMWDP #551
LMWDP #551
