Ponte Vecchio Export - Page 2
espressotime (original poster)
#11: Post by espressotime (original poster) »
Tjyven wrote:Thanks! Maybe OT in this thread but isnt the Lusso a thermosyphon or am I misinformed?
To my knowledge they're all dippers.
baldheadracing
#12: Post by baldheadracing »
The Lusso uses a thermosyphon - Ponte Vecchio Lusso Review
#13: Post by espressotime (original poster) replying to baldheadracing »
Wow.I did not know that.Great stuff.
baldheadracing
#14: Post by baldheadracing replying to espressotime »
I don't think that it has a cold-fed HX, though. I remember reading somewhere that the thermosyphon is circulating boiler water but I can't find the reference.
I do remember that the two-group version of the Lusso uses one thermosyphon - the two groups are bolted to a manifold which the thermosyphon is attached to.
peacecup
#15: Post by peacecup »
Lusso is a thermosyphon. A very nice daily driver with the same espresso quality as the Export.
LMWDP #049
peacecup
#16: Post by peacecup »
Yes it just circulates boiler water with no hx. Very temp stable though, well designed for its purpose
LMWDP #049
baldheadracing
#17: Post by baldheadracing replying to peacecup »
Thanks for confirming.
I think that 'Club' machines are a perfect size for many folks. I wish my Oly Club had a similar thermosyphon setup as the Lusso. (The Oly is a dipper so it takes a good 3/4 hour to warm-up - a thermosyphon would probably cut that time in half.)
#18: Post by espressotime (original poster) replying to baldheadracing »
The Export is a dipper too and takes 10 minutes.
MCal2003
#19: Post by MCal2003 »
Have a 2 group PVL. Assuming outside of a larger frame and 2nd group the design is the same. Thermosyphon group heads. PV's fit and finish on this specific machine is a bit lacking. Overall design looks to be an afterthought. Tried to squeeze two groupheads, water wand, steam wand, gauge onto too small a footprint. Also, no anti-vacuume valve. The good is you can pull shots as fast as you can dose, tamp, and lock. Like the Export. Heavy crema. Export is the "better" value.
LMWDP #151
RTM
#20: Post by RTM »
I have a Sama export, with some TLC it's a wonderful machine!!
I am no barista, but I've gotten to the point where I prefer my coffee over most
I usually dose 16-17g, if I underdose I get a divot in the puck and a runny second pull, but dosed right it comes out great!
what dose are you using?
