Polish advice (I did something stupid) - Page 2
I suppose at this point the damage is done. You could embrace the worn/patina look or repeat the process with the citric acid and remove the rest of the plating leaving the parts copper. Personally I think the copper looks nice and you could always replace or replate the parts any time since the machine is functional and the issue is only cosmetic.
- drgary
Very helpful. Then the tool offered by Stefano's Espresso Care is an option for going through the top. It would save time and may not cost more than a socket wrench with an articulated joint and an extender.RobAnybody wrote:Standard wrenches won't go through the fill opening, you would have to resort to removing the heating element and going via the bottom with a socket wrench (socket on a articulated joint with an extender pole). You"ll need a metric size 16 socket for that.
Cheers,
Rob
LMWDP#308
LMWDP#308
