Paint stripper inside Zerowatt 708 boiler?
Hello,
I have bought a Zerowatt CA 708 Made in Spain and the paint inside the boiler is flaking due to aluminium oxidation.
Since I would like to use it to make coffee, is it safe to use a paint stripper inside the boiler or is it better to use sandpaper and elbow grease?
Thanks
Thanks
- redbone
I found this to be an issue with the "made in Spain" version as opposed to the "made it Italy" version which I own.
Luckily my Italian version has a pristine boiler interior.
With regards to removing the paint. I guess you can always use a stripper as long as you remove the entire piston assembly and flush profusely post.
You can also use a light wire brush attached to a rotary tool or drill. Be careful not to be overly aggressive and form deep scratches on the malleable soft aluminum.
Exposed aluminum will be fine for water usage once a oxidized protective layer develops. I would add de-chlorinated water with and oxygenator like Nellie's Oxygen Brightener https://www.nelliesallnatural.com/shop/ ... ner-pouch/ overnight in tank to speed up the process. Do this a few times and you will see the initial bright aluminum darken to a grey.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Thanks for your reply,
I was thinking about paint stripper to avoid removing the heating element, otherwise the drill would have been the best option but I'm not sure if I can remove the HE without breaking anything.
- redbone
The 708 it one of the most difficult heating elements to remove.
If you can avoid removing it do so and leave it in place.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
