Olympia Cremina vs. La Pavoni Europiccola with same coffee - Page 4
I have to wonder, if it's a slightly older cremina, does it have the heat break gasket to prevent the group from getting too hot? That could help explain why it's harder to dial in.
I made a decent espresso today with the Cremina. A noticeable lack of Crema which I will have to work on, but it wasn't bitter or sour. I will try again tomorrow with the other beans.
- drgary
I have a 1987 model Cremina and 1961, 1964 and 1968 model La Pavoni Europiccolas. I have owned a 1996 and a 2002 Europiccola. I get consistent shots on any of them when using a fresh and adequately rested medium roast coffee, a quality adjustable grinder (whether it's a Lelit PL53, a Mazzer Super Jolly, a Pharos, an HG-1 or a Niche Zero), a scale that measures to at least a 10th of a gram, measuring temperature outside the group at the start of the shot, having boiler pressure set at about 0.8 bar, adequately pre-infusing, and stopping the shot when it goes blond. All of these machines are capable daily drivers, although the 1961 Europiccola is a museum piece that gets little use.
It's useless to try to compare the Cremina or La Pavoni without getting one of them working consistently. This involves getting the boiler pressure right. The quality hand grinders mentioned above should work. Dark roasts are more challenging to pull than medium without knowing how to keep group temperature cool, which requires measurement.
LMWDP#308
LMWDP#308
I think it is from 1982?drH wrote:I have to wonder, if it's a slightly older cremina, does it have the heat break gasket to prevent the group from getting too hot? That could help explain why it's harder to dial in.
DrGary's comments are right on.
If it's 1982, chances are a heat break will help a lot.
This might be the right one (Cerini can help you be certain it will fit):
https://www.cerinicoffee.com/products/o ... a-machines
I have this for my 1983 Cremina. Very good.drH wrote: If it's 1982, chances are a heat break will help a lot.
